Anyone have any information on the swap. I have the engine and in the process of changing the timing belt. Simple, but any wiring help on the new engine or is it all about replacing the sensors with my current ones. Any help would be appreciated, any help at all
What engine you swapin? what came out and whats going in? engine numbers may help? <_<
Because of whatn is said it is hard to tell I believe it to be a 5efhe , but without taking of the head who knows. Any other way to tell. It has acoustic intake blah blah instead of the american efi Badge. I cannot tell. If not then it is the 5efe. Which should be easy but after seeing the cut harness, I dont wanna get confused, which isnt easy but nevertheless.
Will the wires be a direct match (solder them) or should I change all the sensors instead.
