1c/2c-t Interchangeability Of Cyl. Head
Dal3
I bought an 84 Corolla 1c with a damaged cylinder head.
Then bought a good 2c-t cylinder head.
The seller of the head said the engine bores are the same and the heads are interchangeable.
I've since researched this, briefly.
The specs I found say the 2c-t bore is 3mm larger.
I haven't had a chance to compare the heads, otherwise.
Can the 2c-t head be made to work on the 1c?
I have a gasket set, that is listed for either engine.
Thanks,
Dale
