Just wondreing if anyone has tried this product.It is meant to clean induction and fuel lines and at the same time clean the internal combustion parts of the engine claiming to lower immissions and give you more mpg and clear the cat.Supposed to be suitable for both petrol and diesel engines.Even claims to reduce engine management errors.
www.cataclean.com
Looks pretty good to me, would be worth a look when I get the motor running again. :yes:
Sorry but I don't listen to any of that marketing guff
It's not a fuel additive........but strangely enough you add it to the fuel? Hmmmmm
There are umpteen different types of additive on the market, think I would prefer one of the market leaders IF I were to need it
Kingo :thumbsup:
  • 5 months later...
If you can find a product called SeaFoam that will do the job in removing all the carbon build up out your engine, but there really is no such thing as a cat cleaner fuel additive if you need a new catalytic converter its usually because the one you have has melted and you would need to get a new one.
