Loose Trim Above Number Plate
Hem-lag02
Avenesis H/B 2004.
The trim that has the number plate lights is loose on my car. My question is, can I tighten the trim. The reason that I ask is because at the last service I asked Mr T to tighten the nuts but they came back with I can not tighten it, need to replace the trim at a cost of £95.00.
I have tightened the trim but overtime is becomes loose again.
Welcome any advise .
Hem
Avenesis H/B 2004.
Hem
Could you not rethread the trim ?
Could you also retighten the trim again, but use loctite 243 - lock n seal on the threads ?
Did this on the inside of my motorbike engine, and nothings shaken loose yet
Bazzer
Bazzer
good idea
