Ultra Sonic Injector Cleaning
DSOTM
Sounds glamorous, but is it any good.
Im fairly sure the injectors on my Gen 7 need cleaning. I have used some cleaner you put in the tank, with limited results.
I have seen a couple of companys offering an online postal service, anyone used them, any recomendations, or cowboys to avoide?
I'll ask this one before someone else does. What makes you think your injectors need cleaning?
Loss of power, very flat when I change up gear and the revs are below 1500-2000. or go up hill, the power just falls away
I changed the plugs and air filter. Had a new air mass meter too
I cant think what elce it could be, its got 95k on the clock
I presume you're getting no fault codes up?
The reason I ask this is cause it's very odd that injectors would need cleaning on these unless you're been using really rubbish fuel - but even thats fairly rare in this country.
Does the car drink oil? Has it had a compression test? Will it rev to the redline or does it feel suffocated like the cat has gone?
The cat ??????? ouch !! Can the cat be tested ?
Yes it does drink oil, no I havent had a compression test
Not sure about the redlining
When you pull away, and change gear its realy flat untill you get to 2-2500 RPM
