1.8 Gls Not Starting (again Ahhh)
peterc.lewis@blueyonder.co.uk
Oh joy! SHe won't start again.
Just to remove any possible red herrings.
Battery is realtively new ans appears top hold a good charge, not struggling to turn the motor at all.
Ignition switch issue was resolved with a new one last year.
Recently had starter reconned and she started ok after this.
It now appears that either the immobiliser is stopping the car running or there's no fuel getting through. Tank is at least a quarter full(well according to the guage it is).
Symptoms.
Car turns over off the starter switch but does not fire.
No smell of petrol at the exhaust.
Can hear fuel pump "cycling down" when I switch off.
Central locking from key fob may be suspect (off both original keys) though it does seem to be ok now.
The only thing I can think I've done differently is that I locked the car using the key fob yesterday and unlocked with the fob. I don't usually do this as I've had to disconnect the alarm siren (ages ago) because of the usual corrosion issue. Ran OK after this and I had started and stopped a numnber of times. This morning NOTHING!
HELP!
Please ignore this post. It's a duplicate .
Cheers.
