Hot And Cold Celica Gt4
waz66
hi all got a prblem with my gt4 185 its been in the garage and had the head gasket change which was fine i took the car out for a spin and after awhile the temp gauge went up the heater started blowing hot and the cold it seem to over heat when i was putting the car through its paces the car is back in the garage and a new stat as been put in but still having the same problem the garage is having trouble trying to find whats causing this
if anyone has had this problem or knows what is causing this would be very grateful to hear from you or anyone who has any advice for me
thanks waz
thanks waz
hi mate
- have you repaired at dealership or private garrage???
- what abour pump perfomance?
- have they installed gasket correctly not to cover some coolant outlet holes on the block?
- is your thermostat in order?
Start investigation and revert/Cheers/Igor
thanks waz
hi mate
hi mate private garage but he is toyota trained
so m asuming the head gasket waas fitted correctly
dont know about the pump was going to change that next
the thermastate has been changed
do u think the pump is faulty??
cheers waz
thanks waz
hi mate
cheers waz
hello again
the pump is very important thing
have they installed thermostat correctly???
there are no miracles in the technic -- so somewhere is a problem:
- air inside;
- coolant pump;
- radiator blocking;
- thermostat failure;
- head gasket was tighten incorrectly;
You'd start to investigate.
Good luck/igor
thanks waz
hi mate
cheers waz
hello again
- air inside;
- coolant pump;
Good luck/igor
sorry - forgot to ask - -is your radiator equipped with el fans??? please also conside its performance or el control system goovernored by themp sensor located on the cyl head ----- by the way -- have they connected el wire to this sensor??? sometimes it happens and this one tries to give a sygnal to el fan but can not :D
Cheers/Igor
thanks waz
hi mate
cheers waz
hello again
- air inside;
- coolant pump;
Good luck/igor
Cheers/Igor
hi mate
im going down to the garage so i will check this out were on the cyl head is this sensor is it above the water elbow sorry dont know much about this engine still learning
reguards waz
thanks waz
hi mate
cheers waz
hello again
- air inside;
- coolant pump;
Good luck/igor
Cheers/Igor
hi mate
reguards waz
the idea is to measure the max coolant themp -- so it might be on the outlet pipe from cyl head or oon the cyl head -- just to locate it.
cheers/Igor
Have you tried a new rad cap??
Some people have had similar issues and sorted it with a new cap.
