Corolla Verso Dvd System Help
Hi, recently acquired a 2004 Corolla Verso T Spirit with the DVD system and 2 screens in the back. However, got no instructions on how to use them so im completely clueless at the moment, I have a remote with it, the system lights up, I put in a DVD but the system ejected it straightaway.
Also, the monitors dont come on at all, tried pressing the power button etc but nothing. Just hoping at the moment I'm doing something wrong otherwise its going into the garage to get it fixed if its a bigger problem. Any help would be appreciated!
Could be the monitor(s) have become disconnected. If you remove the head rest (carefully!) there is a plug & socket down inside the seat. Had this happen with one of mine.
Have you got the headphones? if not replacements from Toyota are V expensive but I think you can buy others that will work just as well.
What sort of DVD did you try? If its one you burned yourself then suggest you start with a shop-bought one & get that to work first.
