Noise From Brakes
Paul McAtee
Hi just a quick question
I get a noise from the drivers rear wheel, Im guessing its the brakes as wen i apply the breaks the noise goes away. It almost sounds like a rubbing sound however the questions is if i took it into my local dealer which in this case would be SDM falkirk would they look at it under warranty without charging me for just looking at it? or dose the warranty exclude brakes.
Mileage is 13500
08 Reg
Regards Paul
Mileage is 13500
08 Reg
Regards Paul
warranty does include brakes had mine at sdm falkirk 3 times for brakes. Still squealing ????????
My T180 brakes always make a horrible rubbing sound for the first few minutes after starting up, especially if it's been raining. My Aygo does the same.
Plus if I wash the car the back brakes are always seized the next morning due to pads being stuck to the discs!
At first I thought it was the handbrake mech seizing, but it's free as a bird.
It must be something to do with the disc material, as I've never had the problem to this extent with any other vehicle I've owned.
