Door Seals
ReaperGFX
hi all
im getting quite alot of problems of condensation or wet windows inside of my celica, (140 51 plate) radiator is fine so i imagine its the door seals, or is this a common problem.
also where can i pick up seals from and how easy are they to remove/refit
thanks for any info
reap.
hi all
thanks for any info
reap.
Hi
I used to get that as well. I found that if you dry off the condensation with a good absorbent cloth, then remove the cloth from the car, it's fine. If you leave the cloth inside the car, the moisture will dry out of the cloth and back into the car! Try that before tackling seals.
I also noticed that when I had 2 people + me, inside, it was difficult to keep front and rear screens free of mist.
A common place for leaks in the Generation 7 Celica is the boot lid, water leaks in where the spoiler is mated to the boot lid.
