It Started With A Little Drip...
speedyts49
Today I think I may have ended my saga of the little drip.
I found a small bit of liquid under my Taco one day and after talking
to a few people decided it was the water pump. I shopped and ended up
buying a new one at the dealer, $114 spent. I replaced it and the 3
belts while I had it all apart. A few days later I saw the liquid
again making me think i had not torqued the bolts correctly or had a
gasket leak. I searched and asked more people about this and then
proceeded to find thelocation of the leak once again. I got under
the Taco and saw little droplets on the bottom of the tranny and
looked up and saw them on the head gasket which sent chills through
me. Looking further up(I'm still under the truck) I saw a drip
coming from a connection. Ahh thats it! When I bought the truck I
used one of those Prestone radiator flush kits which required me to
cut the heater hose and put a 'T' in between to attach a garden hose.
I replaced the heater hose,$28 spent. Ok no more leak!
I recently had my alarm professionally removed ,$35 spent, after an
episode I had at the hardware store where somehow it was armed even
though i never use it and I could not start my truck. I got it
started somehow.
So anyway, I am driving down the road and my 'check engine' light
comes on and I'm thinking now what. Was an electrical thing related
to the alarm or what. I talked myself, with a little help into
buying a OBD 2 scanner, $139 spent. Finally using the internet I was
able to locate the truck connection for the scanner. The Haynes
manual was useless! I run the test and get P0171 fault which is 'lean
condition'. Let me think, I just had put a OEM air filter back in and
replaced the K&N but that should of made it richer, right? I also
over filled my window wash and fluid spilled on several sensors, ahh
could that be it? I cleaned all sensors with contact cleaner and
reset the taco computer by disconnecting the Battery. Now my idle is
way off but with the help of the internet I found out that the
computer needed to reset itself which it did and then the truck idled
fine. The light came on again after a short drive! I go to the
internet and see a list a mile long of things it might be. I found
out a fuel filter is $35 so I would look a little more before
purchasing one. I start the taco and pop the hood and hear a whoosh
sound, ahh a leak perhaps. I had knocked a vaccum hose off the
canister and the engine must of been SUCKING air. Air leak was on the
mile long list by the way.
Now time will tell if this ends the saga but I truely think I have it
fixed this time.
I now kind of know how that little dutch boy must of felt when he saw
that little drip.
tom
'96 taco 2wd 2.4L
:P
I admire you for doing most of the work yourself. I'd have taken it to the garage half way through and let them rip me off.
I do ask how much something is going to cost and then say 'Fine, do it'
