Car Starts Then Stalls And Then Wont Start
wuly1554
going too work this morning started car no problem,
5 sec later car just stalled without me doing anything then wouldnt start again and started to flattern the Battery
jump started and went to work,
10 hours later finished work got back too the car and exactly the same thing happened again
Sounds like a fault with the Battery. If you get it going with a jump start, it has to be the Battery. Whether it is a bad Battery, bad connection or not getting charged enough with lights on, heater at full etc. you will need to discover.
Cheers,
Marv
5 sec later car just stalled without me doing anything then wouldnt start again and started to flattern the battery
hi mate
your problem is thet (+) has shurt cut with lead package inside of Battery -- i had the same resulting to Battery change -- now all is fine.
i presume you ca not relay on yr Battery - cos it is either starts or flatt, but the indicactor shows blue circle on the lid -- correct?
CHeers/Igor
