Engine Will Not Idle Once Warmed Up
Younes
The engine is playing up, basically once the engine is warmed up, ie 1/4 to 1/2 way mark the car will not idle and just cut out. Its fine when cold.
Any ideas what it could be? Coolent temp sensor possibly? or Some kind of Idle control Valve?
Could be a faulty coolant temp sensor as you suspect. A simple test with a multi-meter should reveal is there are any problems.:)
hi mate
i would clean MAF sensor + throttle first.
Cheers/Igor
hi mate
Cheers/Igor
Silly question but what does toyota refer to as the MAF sensor? I can see things like vacum control valve, intake air control valve would one of those be it?
hi mate
Cheers/Igor
it is Mass Air Flow meter
cheers/Igor
hi mate
Cheers/Igor
cheers/Igor
Thats a mass air flow meter... I see nothing like this on the car...
Have a look at this posting about egr cleaning this a maf on it. Although that maf is as fitted to the 2.2 d4d diesel I would expect it to be similar for the petrols.
hi mate
Cheers/Igor
cheers/Igor
If it's like the 1.8, it's built into the air filter lid. (similar to the one in the previously posted link from caveman)
hi mate
Cheers/Igor
cheers/Igor
There is no MAF and no EGR that I could see... anyone with a 2.0 VVTi can confirm???
Toyotas don't have that kind of MAF, it's a lot smaller. If you have a 2.0VVT-i (D4) it sure has a EGR and should have a MAF also.
11439-11587-full-toyota-mr2-zzw30-1800i-roadster-vvti-air-flow-meter-maf-air-sensor-1-663.jpg
The 2.0 vvti engine does NOT have a MAF sensor. I have had this confirmed by my local Toyota dealer. (I have a 2.0 vvti)
