On what sub frames or other parts can one safely use a trolley jack?
Can one jack up two wheels at same time?
Yes... I used two trolley jacks to change my wheels and used the same jacking points as used with the standard jack that comes with your spare wheel...
Just make sure that u are on a completly level surface, chock the wheels you are not raising and use axle stands if possible!
James
James
I was looking for some other parts underneath that were safe as my trolley jack has a flat plate as against the V of the jack supplied.
Put a bit of wood on top of the jacks plate to spread the forces over a
larger bit of the lip the regular jack fits over, then you should be OK...
