Help With Old Avensis Turbo Diesel
bigconor
just bought a 98 avensis td,rpoblem is i went to change the interior light when somethings happened,my central locking wont work,the interior lights wont work,nor the clock or a display light. i take it iv blown a fuse somewere but could 1 fuse affect the above,any suggestions.
check dome fuse in engine bay fuse box
hi there im a bit of a fool,what is a dome fuse and how do i check it
if you lift open the bonnet next to the Battery is a fusebox.
ontop it says dome, ecu headlights.
open the box, replace the bad fuse.
