I know this will make me sound simple, but how do I get access to the rear light cluster in my Aygo Blue to change the brake light? I can't follow the instruction diagrams in the car manual!!!!
What do you mean that you can't folow the instructions?
To access the rear lights you have to undo a nut on the inside of the car.
You MIGHT be able to reach it with a socket on a swivel atop an extension
on a ratchet, but in miy experience thet doesn't really help.
The Manual tells you to remove the plastic on
the C-pillar to help access the nut for that reason...
I just replaced both nuts with wingnuts last time I was "in there"...
I told you I would sound thick. Looked again and found the nut! Still not obvious from the pics in manual!
