Does anyone know how to do the valve clearance on a ep91 starlet sr?
Hello mate i've got a starlet sr to, pritty cirtain thet they are hydraulic tappets not adjustable unless you shim them. are they makin lots of noise?
yeah quite a bit and its ment to be done on the service but not paying toyota prices!
Does your car not have a label on the underside of the bonnet?
I'm sure this mentions valve clearance for both 4E-FE & 5E-FE engines!!
If you haven't I'll have a look at mine when I get home
If it's a 4E-FE:-
Inlets are 0.15-0.25mm (0.006-0.010 thou.)
Exhausts are 0.20-0.30mm (0.008-0.012 thou.)
Clearances to be checked with COLD engine and they are shimmed.
:crybaby:
