Levin Help
josewick
I have a AE-101 93 model. Just picked it up and found that the idle speed is a little high.. When start from cold, it shoots just under 2k.. when warm (fully)it is still around 800, sounds about right cos seen the stickers under the bonnet says should be about 800.. But would like some Levin owners to confirm.
very please wiht the car and good on drifting too :P
regards
  • 3 years later...
just incase u read this, mine does the same, i unpluged the Battery and disconnected the ecu and seems to have calmed dwn a little bit, i thinks its just auto choke
  • 8 months later...
I have a levin AE111 20v 1997, so I don't know if this helps but - mine also revs up to JUST UNDER 2k revs, and on idle warm it stays around 800 revs. So unless mine also is abit dodgey, I can confirm that not only yours does that. Henceforth meaning its completely natural- just like a blonde with brown eyebrows :P
