Check Engine, Vsc,tc Lights
DavyNI
The check engine, VSC & TC lights came on in the car this evening.
Is there a way to turn the lights off & is the car safe to drive with them on?
The car is a 2002 2 litre SR saloon.
Ref the above post, the lights are now off.
I checked EFI fuses & they were fine. Then moved to lamda sensors & found one was not pushed home correctly.
Having blown the dust & grit out of the plug I refitted it & the lights went out.
Hopefully its cured but I will get it checked on a diagnostic reader.
