Multi Function Display.
bokkie
On the MFD there is a screen that shows three lines (if I'm correct) of dashes like
From what I read elsewhere I get the impression those might have been used on the Aygo or Yaris (not sure which) for displaying the estimated range for the fuel remaining in the tank? If that's correct, do you think Toyota would implement an upgrade (software?) at some time to display the same or something reasonably equivalent?
These lines shows the illumination of the instruments.
You can change (not possible in AUTO-mode) the setting: pressing the MODE-button. :yes:
