Lowering My Yaris
YARIS_99
i was thinking about lowering my yaris 1999 1.0
i know i will need lowering srpings and dampers, is there anything else needed to do the jobs properly?
i dont know if i'll need a camber kit or not?
Thnaking you in advance
Theres three main stages of lowering:
Lowering springs on standard shocks
Lowering springs on aftermarket shocks
Coilovers
You don't need new shocks to have lowering springs! Most of the springs available are either -30mm or -40mm, a lot of people swear by the Tein S.Tech springs (-35mm front and -38mm rear) as being the best springs.
Shock wise, theres a few available, Koni and Spax are just two, some have damping adjustment and some dont.
Coilover wise not all kits have damping adjustment (like Tein Basics), but many do. Not all coilover kits have camber adjustment either (no aftermarket dampers have camber adjustment).
Often people get a pair of upper strut tower braces too when fittng springs/shocks/coilovers, most use the OMP ones, but a few others are available too.
Hope that helps...
Coilovers
Hope that helps...
ive found some apex springs and shocks for a relly good price, i havent quite got the mony for a coilover kit at the moment. its jus that someone told me i might need a camber kit and im a bit tight for cash. but i dnt wat to do a half job.
