Keyless Entry Question
wardude
Just been reading the manual and it says if the Battery in the keyfob dies, you can open the door using the small key in the fob and start the car by holding the Toyota emblem on the key fob on the start/stop button. This will start the car?????? One question though, my keyfob aint got a toyota emblem on it?
Just been reading the manual and it says if the battery in the keyfob dies, you can open the door using the small key in the fob and start the car by holding the Toyota emblem on the key fob on the start/stop button. This will start the car?????? One question though, my keyfob aint got a toyota emblem on it?
hi mate
-yes you can open/lock the car by using this key -- it works + lock gloves box;
-even you ve lost an emblem -- it must to start, anyway -- cos i deem the emblem is only side check point to turn it in right position. Cheers/Igor
Sure i read somwhere you get low Battery warning in display which should give you time
to change Battery, i normally swap key with spare every 6 months & not had any probs.
although only had car with keyless entry for 2 months.
