Auxillary Belt Replacement 2008 D4D Avensis 2 Litre
marco polo
is the auxillary belt replacement handy to do , is it an automatic tensioner or manual , does it run off the water pump, it is a timing chain engine so i was wondering if the auxillary belt runs the water pump and if replacement is handy cheers lads
not too hard to do, just a bit fiddly getting the belt around all the pulleys.
tensioner is automatic (you will need a 24mm spanner to move the tensioner)
it does run the waterpump/alternator/ac compressor and power steering pump
Mart.
