Error Code P1346
pipin
hihope someone can help on my way home from shops my engine managment came on on gettin home read code, it came up as p1346 i have been having problems with rough idle car cutting out , i tried the maf cleaning and has helped a bit ,but was wondering if this can throw up this code
You wouldn't adjust the tensioner but have it replaced along with the timing chain if this was necessary.
I don't know the age or mileage of your car but mine is a 52 plate with 0ver 80k on the clock and has no sign of chain wear, also the history of the car might have some bearing on the problem
