Aygo Alternator Removal Help!
Hi, can anyone help with how to remove the alternator on an AYGO as both bolts are loose but it won't budge. Thanks, Jim
Sorry Jim, I can't advise on your stuck alternator.
However, any chance of info to the background to the fault?
What were the symptoms, how was the the fault diagnosed and the alternator identified as the failing component.
How much was the new part and where was it bought?
1 12mm bolt at the bottom 1 14mm at the top and leaver out(it will be tight up top(remember disconect the bat and the wires from the alt before removing.. :thumbsup:
