1998 Td Clutch Problems
bigconor
iv a 98 avensis td the clutch is getting hard to change gears it has to be floored to get it into gear.i believe this is a hydrulic clutch is it possible to adjust the clutch on a hydrulic model the way you can with a clutch cable,cheers
