Adjustment On Door
mick1020
Hi all .
I was just noticing that my front passenger door has started to catch a little when shutting it , the panel gap looks less between that and the front wing than the gap between that and the rear door . Could someone please tell me if they can be adjusted slightly and if so how to do it . Many thanks :thumbsup: mick
It shouldn't need it unless it has been interfered with in the past but here you are;
Door.pdf
Door.pdf
Cheers AM . Cannot think why it needs it , its maybe been took off before i had the car .
