Noise When Turning Left On My 2003 Celica
sipick
Hi everyone
I have a rubbing/scrapping noise coming from the front near side. It mainly happens when you have full lock on left. it sounds like something is rubbing any ideas what it could be?
Hi everyone
There are several things it could be. The first I would look at is the brake disks.
The pads may be touching, the caliper may be loose, or the wheel bearings may be worn.
Try jacking up the front wheel, turn it to full left, turn the wheel and listen for any sounds.
At the same time catch hole the wheel and see if it rocks up and down or side to side.
Bos
If it's not something rubbing, I'd go for a universal joint on your driveshaft.
