hi
How hard is it to remove my front air con rad the pump has been remove from the engine is it just a case of taking off the front bumper unbolting it and chopping the pipes or is there more to it ????
thanks
wayne
Are you talking about removing the radiator?? Radiator's easy... Remove the hood latch, pop off the black covering, drain the radiator, remove 4 screws, 2 fans, and 2 lines.
no the rad in front of that
