I'm new to the forum & have a query on my Aygo bluetooth. I finally got to grips with the voice recognition (almost - I don't think the lady copes with accents too well though)& set everything up by shouting a lot. The problem now is that when I do manage to make a call, apparently I can hardly be heard. I've turned the in-call volume up to max, shout, have no fans blowing/windows open - in fact was just stationary on the drive to try it out! Can anyone advise on how to improve things/ My phone is pretty old, so could this be the problem?
Apart from this, which is not a big deal but I would like to get it working seeing as it's there, I love my Aygo Blue. It was hard to send my 11 year old Yaris to the scrappage pile, but I'm happy now.
I have a Blue and mine behaved like that.
While it's true that the fan destroys the sound quality due to poor wiring (No suppression).
I found that the hole on the mike had some dirt in so I carefully cleaned it out and all was well.
Also having the mike facing you helps no end when I first tried mine the mike was set centrally so people complained about low volume.
All I did was pull it off the head lining and angle it at me, the Velcro tab doesn't damage anything so it's easy to move.
I have attached the Aygo bluetooth PDF for you.
It has been virus checked :D
The BT on our Blue seems to have become more reliable with use; don't know if thats just my imagination or not - but voice commands seem much more easily accepted (than when new) and I have found shouting doesn't really help: the key being speaking clearly.
I find the BT quite useful.
I have attached the Aygo Bluetooth PDF for you.
seen in this manual that music streaming via bluetooth is an option. Don't recall seeing that option on mine. Has there been some
kind of upgrade?
I had similar sound issues with mine.
It was easily resolved by un-velcroing the mic from its current position, turning it 45 degrees so the microphone hole faces my head, and the issue was resolved.
