Lowering Springs
vitiqo
Im looking for some lowering springs lower than 35mm in front.
I cant find enything lower. does somone know if its posible to find som lower springs out there
Yes there are TEIN S-Tech springs, -60mm lowering...
Best regards, Alex
Toyota motor sport springs are on my car says they lower 30mm But I measured it at 42mm front 38mm back check out the pics on my profile.
Best regards, Alex
I tryed to google that springs and entered the tein website, but did not found eny 60mm spings.
do you have enny partnumber or websites for the set you have?
Here you go! They're not for Auris originally, but can be fitted. The car isn't mine, it belonged to one of the previous members... He sold it some time ago :)
Best regards, Alex
I recommend you to see the Eibach springs. Are the same as Toyota TTE springs, and cost nothing more than 150 pounds.
Some people here in Portugal uses these springs and are very happy with their behavior!
  • 9 months later...
Does anyone know if these Tein springs fit the T180. I have tein on my st205 hense my preference to use them again. Biggest concern is the spring rate on these and if they are srtong enough to take the weight at the front with the heavy diesel unit
