Smoke On Heavy Acceleration In My 2.2 Diesel
The Cav
Hi lads /lasses
1/ My 2.2Avensis runs superbly
on both the motorway and urban roads
the only problem seems to be if I'm just trundling along
and i suddenly want to accelerate rapidly the car will eject a cloud of grey/black
smoke, now i know its a diesel so is this normal and taking into consideration the 101000 mls
on the clock, The car uses no oil or water
2/ Does the Avensis have a FAP filter type arrangement like the French cars to
keep the emissions down on the burnt fuel
3/ Does my 2.2 have the 5Th injector I've read about on this forum if so where is it?
its not readily visible on the top of the engine by the Heater-Glow Plugs
I have had diesels in the past inc a VW T4 but never took too much notice of whats coming out the exhust
My mate says it only does it on the initial acceleration so dont worry its normal its just cleaning out the engine
Thanks i look forward to your replies
Phil
well i gave the avensis a good thrashing
and now it seems OK
only smokey when cold
maybe its just because its been run around town
do they have a fap type filter arrangement to keep the emissions low??
The dreaded EGR valve
My daughter had a Megane 1.9 Dci.... fast as hell
but always having trouble with the FAP and EGR valves so in the end Renault wirral took it back
and swapped it for a 1.6 sxi Astra
The sales people said the 1.9dci was not designed for town use and is a fast motorway cruiser
that's why she was having so much aggro with the FAP and EGR valves and she shouldn't have been sold the car without 1st determining its usage
anyway she got a more expensive and lower mileage plus its newer astra as a swap
The issue is not with the bad design
But with over fueling.
surprise surprise
my avensis doesn't smoke heavily now
i sat and reved it to 5000 revs and it seems to have cleaned the smoke away
maybe the AGR valve was choked who knows
but now under heavy acceleration........ no smoke
the smoke is back but not as bad
bearing in mind the car hasnt been on the motorway this week
so it may be a build up in the combustion area of the engine
any way was recommended to use forte diesel cleaner to clean the
injectors etc
so ive bought some from eBay and will ry it when it arrives
will keep you all informed
