Overheating Landcruiser
swaring
I have a 1996 landcruiser 3ltr but on a recent trip the engine constantly overheated and spat the water out of the header tank. I did a lot of long climbs and was towing quite a bit of weight, any ideas what the problem could be?
Steve.
Steve.
Hi Steve
The possible problems are:
- cyl cover gasket blowing out;
- injection timing or poor injection (if yrs is diesel);
- cooling system needs to be flashed + new collant filled iin;
- expansion tank upper lid seal is worn giving comunicating of sytem with an air;
- cooling radiator is clogged from external side;
- cooling radiator is about to be clogged from internal side;
- thermostat failure;
- cooling pump failure;
- coolant level in the expansion tank is not sufficient;
- air in the cooling system.
Check with all above and revert with outcome
Cheers/Igor
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
