Springs To Fit 140 And 190 Brake Gen 7S
BS Celica
got someone sellin a set of springs with 30-50 mm drop. he says they fit both 140 and 190. is this true?
Yes, there's no difference.
No idea how much he's asking, but TTE's (30mm drop) are around £140 from Toyota.
Yes as SA has said there is no difference unless they are US branded and then they will not fit.
50mm drop is severe on a Gen7 and you would need to be carefull at this level on your wheel package.
Eibachs progressives and TTEs are the most usual AF springs used which drop about 30mm.
I run TTE springs and think they really suit the car.
any one got a link were i can get some tte springs from please
Direct from Toyota mate, it's Toyota's official branded stuff.
They'll be about £140 supplied. If you want them fitted too, they should come in easily less than £300 fitted.
IIRC, TTE's are described as a 26-30mm drop. Once they have "settled", it's pretty close to 30.
I'm not too far from you. If you fancy having a look at what the TTE springs look like in the flesh, you're more than welcome to pop over and have a nose.
