Mr2 As A Donor For Celica St202
oldie2008
Hi, guys. I'm new here. ive had my Celica for two years now, I have a 2 litre GT (ST202).
anyway, I need a few things doing on my celica, I need a new passenger side full suspension unit (strut if thats what its called) - I know someone with an MR2 which is the same age as my Celica, this person said I can basically swap any parts I need, use their MR2 as a donor. Can I use the suspension unit??
I ask cos the Celica is a different weight to the MR2 & a different ride height.
Also can i take a rear ABS sensor off the MR2 and use it on my Celica as my ABS light is showing????
& Although I havent had the ABS profesionally diagnosed yet, I had a 'tip off' from a garage that it is most likely one of the sensors that is the problem. Which kinda makes sense as last time I tried, I couldnt get the rear ABS sensors out, they were stuck in with, i presume, muck.
P.S in these two years - the ABS is the only fault ive had on the car, touch wood.
(the strut got slightly bent cos i got caught out in the snow & ended up sliding into a curb - so that is a kinda self-inflicted problem)
any help or info would be much appreciated, thanks
struts wont swap over im afraid and according to the EPC the ABS sensors are common to the celica only im afraid.
you can try TCB (toyota celica breakers) they have new and used spares and are reasonably priced web site here
