D4D 2.2 Difficult To Start After Fuel Filter Change
M.Davies
Can anyone advise on how to bleed the diesel fuel system.
After changing the fuel filter, priming it (button on top of fuel filter), the car starts after 10 seconds. Primed it a number of times but it is still difficult to start and when driving is a bit hesitant. Any ideas on how to bleed the system?
Mathew
I`m sure modern diesels shouldn`t need bleeding after running out or a filter change just primed.
Did you renew the seal and is the filter fully tightened because it sounds like air may be getting in the system.
Does priming help starting first thing ?
Mathew
hi mate
you ve to have yr injj systen bleeded when starting key is in ON position -- this keeps both SCVs open to suct diesel from filter anf recirculate it. the above is in force subject the filter was assembled correctly. cheers/Igor
You must bleed the system before the engine runs right. Keep pressing that plunger on top until it goes hard and then start it. If you still have problems, take the out pipe off and pump it until the fuel runs. Reconnect the pipe and pump it until it goes hard then start it. You can expect it to splutter for 5 or 10 seconds but if it still causes problems you have done something wrong. Take the filter off again and check the seals are not twisted or you haven't fitted 2 seals in error at the top. Lightly oil them with engine oil and refit then re bleed.
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
the benefits of running diesels!
I've learnt this from our generator running out of diesel; the Renault 7 ton truck; and the forklift. Funny. With petrol, you just fill up the tank and away you go. Diesel has to be primed; pumped; connections loosened to let out air;
Why doesn't that happen on planes - have they sorted the problem??
Mine was replaced last week after it clogged completly.
You have to keep priming until the rubber button on top of the filter housing goes completely stiff and keep repeating if necessary mine took 3 start/prime cycles before it behaved.
Rgds
Dave
