ive changed my mind on just stock tuning a 1.3 n/a, so..... what is the biggest n maddest engine i can put into a starlet sportif without doing any major mods to the engine bay, underneath etc..... any ideas welcome
I'm no expert but if you have a look around on these forums it seems the glanza lump is the easiest and most tuneable. anything else will require a bit more fettling of mounts and stuff to get in as far as I know. like I said I'm no expert, but if you have a good rummage through the threads already on here you'll probably find all the info you need
bein a mechanic myself, im up for a challenge, but i really dont know what to go for, a glanza lump i know would b the easiest but its just findin one with loom, plus what the maximum you can squeeze out of the little 1.3.....
