Diagnostics Check On Gen 7
miss_sillycar
Hi all!
Ive pretty much come to the conclusion there seems no way to diagnose the ABS light fault on my gen 7 myself, so gonna take it into a garage to have it looked....been quoted £40 by independents and circa £60-80 by dealerships!!! seems really expensive =(
anyone recommend some decent garages in the Loughborough/Leicester??
Thanks xxx
ive got a obd scanner which might work on your to tell you the fault if thats anuy help im from coventry
dont mind helping a forum member if you coming by this way
thanks shayd!!! i will bear that in mind if i pop by that way!! x
It's often one of the wheel sensors, blocked with some dirt or something. If you're handy like that it may pay to give them a quick check/ clean then reset the fault and see if it returns?
what does it look like?? =(
