Immobiliser
deadman
Hi, im a newbie and i was wondering if any one knows how to disconnect the imobiliser as mine is faulty. i have to turn ignition on 6 or 7 times before engine starts. i would be grateful for any help. thank you.
I'd take your car to a mechanic to get it looked at... advice on how to disconnect an immobaliser could be seen as TOC condoning potentially illegal activities...
You cant!!!
That sounds more like an ignition switch failing, older Avensis are famous for it ;)
Kingo :thumbsup:
Greetings! I advise You to cut out this immobilizer from security alarm. For this purpose You should address to the good electrician. I have made so... thumbsup.gif
You cant!!!
Kingo :thumbsup:
hi kingo, thank you for your comment. you were right it was ignition switch.
