Electrical Problems
Businka
I have an Avensis SOL 2007.
My problem, that suddently both headlights went out.
I'm not good into self repair, but i want to check the fuses first, before going to repair.
I just don't know which of the fuses i need to check, can anyone help me out here?
The fuses are situated in the small fuse box under the front covers over the radiator. Nos
28 LH High Beam 10 amp
29 RH " " " "
30 LH Main Beam 15 amp
31 RH " " " "
Seams unlikely that all four would blow unless there is a short circuit at the switch.
Fitter
