Rear Brakes
riff65
can anyone help i just replaced the rear rotors calipers and pads now the brakes drag really bad is there a trick to doing these
you need to adjust your handbrake bud, there's an adjustment screw behind the disc inside the drum part, should be accessable via a hole in the disc
