Emergency Program When Under Preasure
zakazak
hey , i want to buy a nice gt4 for a fair price. Only problem: owner says there is some sensor damaged. I called him and he told me:
When under preasure (so i guess when accelerating hard) then the car gets put into the emergency program to not destroy the turbo.
Any ideas what could cause the problem? I thought the worst (and most expensive) case would be the ECU ?
thanks
that'll be fuel cut due to the boost being set too high i'm guessing. it should have the fault code stored in the ECU so check it
