:help:URGENT DUDES!!! Need to know the max tyre size for my car. Want to put 205.50.15`s on. Most places have told me 195/50.15 is best but from the tyre size calculator you lose performance with that tyre.
A) Will the tyre fit within the wheel arch safely? (An extra 8mm diameter or 1.38% difference)
Basically the tyre will theoretically give you a 1.3% increase in performance
Cheers dudes
Abraxys
dont know if i can help but here goes.....
If its the wheel widths that your worried about then i know for a fact that 17s with 205/40 17 will fit on the seo without rubbing. i know 97paseo had 15s and Daz H has got 15s on his seo might be worth sending them a pm see what they say.
Hope i helped in some way??!!??
how will you lose performance with a tyre with a lower radius than the 205?get 195\45\15s
I had Yaris SR 15's on mine but have completely forgotten the sizes now - Dazh is your best bet. :thumbsup:
hello
we have 205 /40's on 16 inch rims with no problems
changing rolling diameter to a larger wheel will decrease acceleration and not increase top speed as the limiting factor is the drag
As far as I know, as the Seo had 14" wheels as standard (forget the tyre size), putting 15" wheels with 195x50x15 tyres on keeps exactly the same dimensions as if it were on 14"s with standard tyres <_<
I did a bit of asking round before I got mine as I'm in the motor trade, and every one I asked told me this :thumbsup:
205/50/15s will give u no probs, but u wont notice the difference in performance/grip from 195/50/15s anyway
Cheers dudes for all who have answered.
Found a MENTAL website if your thinkin bout changin tyre sizes its the dogs <the spuds of lurrrrvve>s!!!
http://www.tyresave.co.uk/tyresize.html
or
http://www.miata.net/garage/tirecalc.html
If you check the second link out you`ll find 205.50.15 actually gives better performance.
195.50.15 upgrade means you actually lose performance!!
Was thinkin bout gettin 195.55.15 but a) there no more expensive than the 205`s and B) the 55`s are outwith the 2.5% diameter safe increase (without modification)
N-joi!!
Abraxys
