Where is the reverse buzzer located? Its really annoying me whenever i put it in reverse. I know its a warning, but I know what gear i'm in, so I dont need the car to go 'beep-beep-beep' all the time. I just want to find where the speaker is, so i can disconnect it.
behind the speedometer unit
and you will fail your next MOT, it doesn't matter if they are not fitted to uk cars.
I'm in the uk so it should be ok then yes?
How hard is it to get to the buzzer then? Or is it more hassle than its worth really? I want to fit a reverse parking sensor, so I dont want the two buzzers conflicting with eachother really.
