Engine Manangement Light
mucky fingers
Hi , i've got an avensis 1.8 gls petrol on a r(97) plate. The EML came on after a bit of struggle on starting one morning and later that day went off again. Now its is on all the time. The symptoms to the problem are that it struggles a bit on starting first thing in the morning and it is idling high (1400rpm).The EML does not come on immediately, it takes about 10 seconds after starting. The mpg has dropped slightly. Everything else is fine. It is not the Lambda sensor as i have tried a working sensor.
Any help will be greatly appreciated.
