Weird Celica Alarm Probelm
TiMiX
Hi all, had to jump start my car the other day which set the alarm off. Turned it off using the fob
and now the right side indicator is stuck on permitley! very weird :blink:
The only way i can sort this is to remove the hazzerd light fuse, also resulting in no centrol locking or alarm system.
Has anyone else had this problem? any ideas how to fix it? Im taking a guess the alram has got its self in a twist.
Cheers for any help with this.
Perhaps try disconnecting your Battery completely for a short while then reconnecting and see if that resets everything?
Hi, ya tryed leaving it disconnected over night with no luck.
Its stange as everthing still works ok, the alarm still works fine along with the locking and hazzard lights.
Seems like what ever makes the lights flash when you unlock the car has mel function or something :unsure:
