Fusebox Location?
MXMaster
Hello,
I'm trying to track down the fuse box that has the fuse for the cig lighter socket in my 2009 Auris.
The handbook says under the bonnet, which I have checked and they are all fine, it then refers to an inside fuse box board behind the glove box.... So i removed the glove box only to find NO FUSES or FUSE BOX, just some connector plugs and the air con Cabin Filter!
So where does the fuse box sit?
The panel under the steering coloumn is all on screws so I assume it isn't in there?
Please help...
Thanks...
Just to recap... the fuse for the cig lighter!
