Rattle From Engine When Cold?
PapaHett
When I start the Auris in the morning, it sounds like there's a knocking coming from the engine.. It stops when the engine gets upto temperature. Is this normal, or should I be concerned about it?
The warranty's up at the end of April..
is is your auris diesel or petrol ??
if its diesel i can be normal but atam the dieel engines are modern and they didnt make this sound
i think thats shomting whrong but i am not sure
  • 3 months later...
hello is this a high milage, if its coming from the bottom of the engine,
you have an oil pump problem
the big end bearings could be worn,
have you plenty oil in
