Cat Help
TsportM
how can i get cat out whithout engine light coming on ?
and if there is a way to turn the light of just the light, ill the ecu still recognize the error, becouse if the light is off and the ecu warning is still in the ecu unit its the same only the onoing light is gone,
toyota celica tsport
help me please
When you remove the cat you will have a sensor which comes out of the cat pipe. WHatever type of de-cat replacement pipe you are using there SHOULD be a place to put this sensor back in.
Without a place for the sensor your going to get an error light. THe only other way i could think around this is to remove the sensor, figure out the signal (.i.e voltage) that the snsor gives out when its in normal mode and fit a rsistor or something in its place to provide a working signal to trick the ECU into thinking the sensor is still there.
:wacko:
