I Need To Chenge My Brakes On My 05 Corolla, But I Dont Know What Cali
2000mira
I need to change my brakes on my corolla , but i don't know what calipers i have so i can buy the right discs and pads
can anyone help me with some advice ? I'm new to this, but i love my car :yahoo:
highly likely to be LUCAS aka TRW.
nrgizerbunny - what discs and pads you recommend?
i will use one of your 'How To' to change them
its a first time for me to change the discs and pads :yes:
if you take a wheel off, I suggest the front (so you can turn the steering.)
it is stamped into the caliper.
i would recommend stock discs, pads- ferodo.
Is it important if discs are vented or not? I'm a heavy breaker
fronts are vented, if you mean drilled, you'll crack them so i would say no.
Only if they are put to serious track-day use. :P I've had drilled discs on other cars and they've been fine.
not that much :D just 'normal' Milton Keynes use
You should be fine then.
Didn't know you were in MK! I'm in stony stratford and Wolverton. :D
Or up near Cranfield University if I'm working on the GTi. :yes:
